Gransee
The Arc4+ is now 10% brighter than before! Everyone who has a back order for an Arc4+ will get the new 33 lumen units.
I confirmed a hunch today that our Arc4 efficiency has improved with the second revision. I tested 15 units today and was able to calibrate 100% of them 10% brighter than our previous setting. As a result, I have raised our standards for the Arc4+ from 165k to 182k. This keeps all the units below the 1.25amp @3volt test.
I will test these in the integrating sphere and should get over 35 lumens in most cases. I will advertise them at 33 lumens to give ourselves a safe margin. Even at 30 lumens the Arc4+ was brighter than any other published lumen rating for a single 123 flashlight.
All Rev2 Arc4+ units will be rated at the brighter 33 lumens. If you have a back order with us for an Arc4+, it will be filled with the brighter Rev2.
We are still taking back orders on the new Rev2 for the time being. Supply is limited of course. If you know Arc, you already know about our limited supply by now. /ubbthreads/images/graemlins/smile.gif I expect that the new rating for the Arc4+ will become the standard for awhile because these gains were achieved by refining our initial manufacturing.
Please check the back order thread for more details about how and when the orders will be filled.
Thanks!
Peter Gransee
Thanks!
Peter Gransee
