Re: Lithium powered lights with bright flood beams
[ QUOTE ]
Kitchener said:
In my on-going quest for a stick-in-the-drawer-and-forget, long burn-time LED, it seems lithium power is better suited. The Inova X5 was mentioned as an option. Are there other good options out there I should consider, as well, that meet the above characteristics (bright, long burn time, flood)?
[/ QUOTE ]
I had mentioned the X5 in your previous thread as something that might fit your criteria.
Phaserburn is right that the Energizer L91 1.5V lithium AA cells are functionally equivalent to the CR123's used in the X5 and a light based on them should work fine. Your previous criteria had a price limit of "neighborhood of $25-$35" which the X5 would meet. Have you changed this? There are some excellent lights out there if you want to spend more money. For example, take a look at the
EternaLight EliteMax
This is a great emergency light with the added advantages of being
dimmable and
regulated . Being dimmable means you would be able to trade off run time with brightness--this light will go hundreds of hours on its lower brightness settings, but can also be very bright in its "overdrive" mode if need be. Regulated means that the light can use almost any type of battery successfully--alkaline, lithium, rechargable, heavy duty, etc.--with no performance hits. This particular light is the "top of the line" Eternalight and was recently on sale for about $60. There are also less expensive EternaLight models available with fewer features. I have an
EternaLight Ergo with lithium batteries installed in each of my cars for emergency purposes. I also own the EliteMax which I use indoors (as well as the X5, etc., and on and on...do I need help, is there a cure?)
