FWIW, unless I misunderstand the physics involved, I would think that green would be the worst color for navigating in a woodland environment, as I would think that green vegetation would just absorb the light. The only reason you see military usage of green lights is to not burn the NVDs.
As a detective I had used alternate light sources for crime scene work, but it involved filters that were carefully collimated for specific wavelengths. "Blue" is just too broad to expect worthwhile results from unless it just happens to fall in the near UV range, but then you'd not have much visible light generated. I will admit that my knowledge and experience is a bit dated and may be superceded by current technologies and methodologies.
Anyway, white or red seem to cover my needs.
