gadget_lover
I just came across a new version of the Dorcy 2AA 4LED light. It is distinguishable by the rubber padding that is nicely sculpted and has DORCY molded into it. The old version has rubber grips with stipes. The older version has been sold for at least 6 months. I found the new version at a Sears subsidiary (Orchard Supply Hardware, or OSH for short).
It is notable because it is about 4 lumens brighter than the original and, in my case, it's whiter than the originals. The fit appears to be a bit better, with no machining marks that I could find. The head has been reworked to use the more elaborate contact board that the 1AA-3 LED uses, complete with washer around the edge to ensure good contact with the negative leads of the LEDs.
The original pulled 385ma from a pair of fresh AA batteries as well as from a pair of NiMH that had not been charged in a month. The new one pulled 525ma from fresh cells.
Looking down the battery tube, I can see that the converter board is the same (well, has the same numbers) as the one used in the 1AA-3LED.
OK, time to crunch numbers. 3 volts * .525 amps = 1.575 watts of battery drain. I've seen about 68% efficiency in the past with this board, so I'm gonna guess that it's sending about one watt to the LEDs. That's about 75ma per LED.
I like this because I have it's little brother (the 1AA-3LED) modded to use a luxeon and a 3 volt (one cell from a CRV3) battery. It's also pulling about 525ma. I was worried that it could not handle the current, but I do like the 22 lumens it's putting out.
This new version should make a nice host for a luxeon.
Daniel
Daniel
