D
**DONOTDELETE**
Guest
Greetings everyone, been a lurker around here for a while so I thought I'd introduce myself first
Anyways, I received my LS modules yesterday and have been playing with them quite a bit. I'm somewhat disappointed in the output. After all that I've seen around here I thought it would be much brighter.
I modded my white LS into a double barrel in parallel @ 2.4V and the output is much less than my regular maglight AA and my turquoise arc. I also connected the LS to my 3V mag AA and it was still very weak)Seeing that the output was relatively weak, I placed the light in my series wired double barrel (4.8V) and the output greatly increase, but still unsatisfactory to me. Yes I know thats alot juice
In that same series double barrel I have only four blue led and the output is significantly brighter (at least 3 times more). I was using 1.2v AAA nicads rated at 300mA. Is the 300mA the limiting factor? I've been reading that the LS is somewhat equivalent to 10 white nichia so this doesn't make sense to me. So right now I'm thinking it would have been better to gett an array of white nichias for my double barrel.
Also, to test if it wasn't just that LS, I hooked up my second LS for a brief second and got the same result. The second LS went back into the safe until I destroy this one
Bottom line question is: Which produces more output? A "standard reference" mag AA or and LS running on two 1.5V AA?
