ArmyTek
Results 1 to 2 of 2
Thread: Dorsy Aluminium recant
    Flashaholic* sunspot's Avatar
    Aug 2001
    Graham, NC
    Default Dorsy Aluminium recant
    I gave a bad rating yesterday on another thread but last night I had the time to give this torch a more through going over. Here goes.
    Cons:
    The light output is very weak for a 6v torch. No change there. The supposedly ajustable beam is a crual joke. The lens cover is cheap thin plastic. The switch is somewhat hard to operate. [img]images/icons/frown.gif[/img]
    Pros:
    Save the blister pack. I'ts really tough to cut and can be used to make replacement lens covers. The body is thinner than a Mag but not by much. Don't use it to drive tent stakes like a Mag but it is strong. The whole torch comes apart easily. The bulb is held in the head by a similar method as Mag. Well made considering it's made in China. Some rough spots in the machining but no big deal. The bulb itself is a PR base so changing to a better LED should be a major plus. O-rings on the head and tail. U-channel gasket on the lens. Should be moisture resistive at the least. Nice blue color.
    All in all, with a better bulb, It could be a keeper.
    I am going to send the torch to Stingmon to test to the death. [img]images/icons/grin.gif[/img]
    Default Re: Dorsy Aluminium recant
    phred,
    You are absolutely correct about the output; marginal. I bought it for that pupose (odd as it seems).
