D
**DONOTDELETE**
Guest
I have a CC Trek Light (with the 2 led assembly)that was given to me and it has an led that started pulsing on-off while the other steadily burns. It has a strobing effect that will slow down in rate of pulsing as it is left on then will eventually go out totally. After the light is left off, the led will come back on in the pulsing mode. Is this what an led does when it is going bad or do the normally just burn out? It had been looking dim so I replaced the batts, used it for a while then this started. I thought maybe I installed a batt backwards, but they were in right.
I have sent an email to C. Crane but thought I would also mention it to you guys for any comments.
Thanks,
Clint
Thanks,
Clint
