[ QUOTE ]
Doug S said:
[ QUOTE ]
NewBie said:
(at which the ARC4 is ~9.3 lm/W or about 30% efficient)
[/ QUOTE ]
Your 30% efficiency figure is way too low. That 9.3 lm/W was a worst case value for lumens exiting the light. I don't see any way that you can get from there to your 30% efficiency value.
[/ QUOTE ]
Which did I say was 30% efficient? Is not the end goal, the about of light exiting the flashlight?
Certain batches of luxeons are now 30-35 lm/W. Lower output than this can be lowered by 8% with a non-AR coated lens placed in front of a luxeon, up to 30% loss with aluminum reflectors (assuming all the light hit the reflector, which it doesn't), and even heating of the luxeon die, above 25C die temp will cause lumen output drop (conversely, cooling the die below 25C causes an increase in light output).
Now Doug, we do know that an average of 2.4W is delivered to the LED at level 1, from Peter's statements. He also said Level 1 is an average of 600mA delivered to the LED. Additionally, high brightness binned Lux III can reach 85-95 Lumens at 700mA, where a T bin cuts Lux III off at 87.4 Lumens. Running at 600mA results in about 85% of this. Or, 74.29 Lumens.
[ QUOTE ]
Gransee said: Everyone who has a back order for an Arc4+ will get the new 33 lumen units.
[/ QUOTE ]
33lumens / 74 lumens = 44%
Next:
[ QUOTE ]
Gransee said: This keeps all the units below the 1.25amp @3volt test.
[/ QUOTE ]
So, 3 V * 1.25A = 3.75 Watts going into the flashlight.
Most my Luxeon I or Luxeon III have a Vf of 3.75V at 1A, and about 3.6V at 700mA. I have some that have a Vf of 3.5 at 600mA and some that have a Vf of 3.7 at 600mA. So, lets take an average. Peter is down at 600mA to the Luxeon, so 0.6A * 3.6 = 2.16 W to the Luxeon.
2.16W / 3.75W = 0.576, or 57.6% electrical conversion efficiency at Level 1.
Then you take the 44% Lumen efficiency.
0.576 * 0.44 = 0.25344 or 25.3% overall ARC4 electrical to Lumen efficiency.
Another way of looking at it, is 74 lumens at 600mA for a Luxeon with the die at 25C. The ARC4 is 33 lumens though.
So, we take 33 lumens with 3.75W into the ARC4.
33 Lumens / 3.75 Watts = 8.8 Lumens per watt.
Now, to get real we need to know the input current level and voltage. To nail it down, we'd additionally need to measure the output current and voltage.
With nearly every other flashlight, shortly after it is introduced, CPF members take and make efficiency measurements quite soon. I've yet to see these charts for the ARC4, which is quite odd, and a rather rare occurance.
Strange.
