Hi,
I'm new to LED lighting but have an interesting application.
I wanted to put some undercabinet lighting in my gunsafe and bought some halogens but they were dangerously hot since IA also store ammunition in my safe.
Decided to go with LEDs since they could be battery powered and would not be hot.
The problem is the shelves are fairly close together and each LED projects a small spot light on the shelf. I would like to be able to diffuse or disperse the light broader. Any suggestions?
Ultimately, I'll use 8 pairs of LEDs in wired in poarallel powered by 6 D-cells. These lights will only come on when the door is opened via a door switch. So I'm not to worried about efficiency. Using the LED calculator I should get about 150 hours of use with this set up.
Any other ideas or concerns with my concept?
Thanks,
Pigseye
Thanks,
Pigseye
