Ok, I know this may sound a little off-beat, but has anyone run across the equivalent to a 40-watt or less refrigerator light bulb? My incandescent bulb just died and it made me wonder if anyone is producing these.
Yeah, it would be impossible to justify that kind of price, since the normal life expectancy of a refrigerator is less than 10 years. During that time, you will probably only replace the bulb 3 times. This is not exactly the type of application where an LED prevails.
LEDs should be nice in a freezer as their efficiency is higher when cold and therefore they produce less heat and safe energy and....
OK, I'm shure we will read it here when the first refrigerator with LEDs comes out.
Anybody that can make those, maybe ought to contact refrigerator manufacturers about it and maybe land a contract to make them for some of the higher end freezers and fridges made. /ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/thumbsup.gif
Good luck modders! /ubbthreads/images/graemlins/buttrock.gif
Just wondering if strips of LEDs might be an idea. My only concern here would be the narrow beam angle of most LEDs - it might not make them the ideal source for this application.
They should be ok with refrigerator type diffusers over them. www.besthongkong.com may have the answer if anyone wants to try a serious fridgemod. /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/wink.gif www.Inretech.com also has a 63 led strip if there's a 12 volt supply available inside the delicious confines of the fridge. /ubbthreads/images/graemlins/crackup.gif
[ QUOTE ] reviewum said:
Any easy ways to drop down 120 other than using 37 LEDs in series?
[/ QUOTE ]
The 'traditional solution' is to use a series capacitor. That is Xc which is 'one over two pi times F times C'. That's Frequency in cycles a second (60) and C in Farads.
If you do a bit of snooping around in the electronics forum you'll find some good stuff there, some of the best by MrAl (no surprise considering....).
On a more personal note, you know the LED nightlight you gave me? That way......
I didn't even think about that! Maybe I'll give that a try.... actually, on second thought maybe I should get the lower voltages down before I start messing with things that could give me a good shock!
Hey Mike, does Inretech offer a 12 volt transformer for the 63 led stripled light?
If not, is there a cold, Oregon coast weather, outdoor version of a 12 volt transformer that would work in there? /ubbthreads/images/graemlins/grin.gif
In some fridges, a plug socket adapter could be used to get power to the transformer and to the stripled. /ubbthreads/images/graemlins/smile.gif
