Hi RonM,
This is my first post in these forums, so I will try to make it informative.
I stumbled across this site because I saw a site that carried the ArcAAA but they were out of stock. I traced back the manufacturer because I saw it, loved it and had to have one. Then I ended up here and quickly realized that I may never get a new one at a reasonable price depending on how things go with Mag. So, having been inspired by the multitudes of flashaholics here, I decided to build my own.
In the end, the easiest route for me (lacking milling machines, lathes and quick, easy access to surface mount components) was to buy the Dorcy 1AAA, tear up the circuit and rebuild it to fit into the Solitaire.
I have just completed v.2 of my dorcy/solitaire hybrid and am fairly pleased with its function and performance. I still have some bugs to work out in soldering components that small and retaining the twist-on function of the solitaire as well as securing the circuit pill, but hopefully that will be solved with v.3 of my hybrid mod.
So what I am getting at is this: Do your own dorcy/solitaire mod. Once modded, my solitaire outputs the same amount of light as the Dorcy 1AAA since it uses the same circuit, the same LED and the same power source. But.. It now has the form-factor of the Solitaire which makes it infinitely more EDCable and only slightly larger than the ArcAAA. Granted, my mod isn't perfect and due to the soli reflector and my imprecise positioning the beam shape isn't as good as the original, unmodded dorcy, but I think it is more than good enough for my own EDC and will replace my old Solitaire for EDC purposes.
Just my $0.02 (US, pre-tax) of course,
pb
PS: I will post a new thread later today on my mod in the appropriate section with pics and beamshots.
