Hi guys, I am new here and also new for LED light. Just wonder is it possible to take the shell of the LED away and custom my own shell by using silicone? Is the shell a part of the structure of the whole thing to make it work?
If you're talking about cutting down a 5mm, you should know that many types are also available in 3mm (1/8"). And other shapes, like rectangle, are available. Then there are surface mount!
BTW - speaking of cutting, does anyone know the Brewster angle for the epoxy they use on the leaded lamps?
Be careful, if you take away too much or over heat the epoxy you may tear the wire bond away from the die. There is a limit to how much you can remove.
