NewBie,
I also read your another post (Re: They are back- Microlux Luxeon Solitaire lights!). I am very impressed by your mod, focusable, candle mode, etc.
Recently I just finished a CMG Infinity mod and I am planning to mod my 15 years old Solitaire. I want it being like yours. But I can't figure out from your pics how you structure the part emitter/heatsink, fixing it onto to the tube. For sure it is not like "LED mods As Small As Possible" mod because his mod couldn't be candle mode, nor a drop in sandwich like Ill Pill. I guess your design is similar to tonyb's Microlux Luxeon Solitaire light. Differences are you remove those "black plastic component", put the circuit components inside the tube and make two pins for the emitter +/- post. But how do you connect them to the circuit? Can you give me some hint?
The other issue is the heatsink problem, in turn-on position, any design like tonyb's mod will make the emitter base board(heatsink) discontact with the tube. That means the emitter can't use the flash body as a heatsink. And it means we can't drive the emitter too hard. Right?
The last question is you mention that your circuit is high efficiency, how do you compare it with the Zetex circuit? I always wondering how the Zetex circuit that is widely used performs compare with such as Madmax, Badboy, Ill Pill and yours. I wonder because I can buy a flash with a Zetex built in with about 1/3 to 1/2 of the prize to buy one such sandwich, and I can easily mod that Zetex circuit to drive harder. There must be some difference.
