Max,
Thats going to take one of the 9.6, 10.5 or 12 volt Welch Allyn bulbs, I don't know if the 9.6 will take that much overdrive, but you can see if the 01126, 01149, or 01154 would work.
You also could try the 01185, driven at 12 volts it is INCREDIBLY bright (somewhere above 1000 lumens) but they have been known to instaflash at that rate. I drive mine with 9 NiMH AA cells in a 3D mag and it is by far the brightest light I own. It's rated for 9.6 volts.
Carley also makes bulbs that will work, both have websites.
Try walamp.com and carleylamps.com.
The most commonly used Carleys would be the 808 and 809, there might be a few others if you look hard.
The 12 volt bulbs will actually be a little underdriven as the voltage drops, but will then last a lot longer.
Good Luck!!
Bill
