robstarr-lite
appreciate any comments / suggestions on diameter and thickness sizes for 3 led moded reflector heads i am planned to swap out the NXO5 optic and use an inexpensive mineral glass lens to protect the led.
first up is the arc LS rev 1 series, next is the 2 AA brinkman and third is the 2 AA minimag. seems the brink and mag are very close in diameter and I've heard the brinkman is slightly smaller in diameter. [ so the brink size may fit the mag ]
another dimension i seek is thickness, what is generally standard?
for use in the arc what is the thinnest thickness I could use. i plan to buy a couple for each series as I've had good results by hand modifying cut down reflectors and swapping out the optics but I need to protect the led and cut down the dust and crud from collecting down onto the reflector.
post or pm is fine.
thxs, rob
post or pm is fine.
thxs, rob
