D
**DONOTDELETE**
Guest
I personally find that the projected circle of LED light with a lens is way cool. As stated earlier, the Brinkmann Long Life LED started it! I liked the beam it produced and attempted to reproduce it with my new LED converion. This lead to a discovery of an even better, more smoother circle of light than even the Brinkmann. My Brinkmann shows the LED wires quite visibly. My conversion lamp does not at proper circle focus. The beam is slightly brighter with internal shadows when it is out of focus, but a smooth, almost shadow free circle when focused properly.
Another source for lens, other than telescope or binocular eyepieces, is an old security cctv camera lens. The back lens of these srew-on camera lens is the ones you want. Most will screw off with determined effort to recover the lens. There are usually 2-3 lens in this part of the lens. Different beam patterns can be had by using one or two a time. Find the best one for you. Experiment with different distances from the LED. The focal length of these particular back lens works out just about perfect for sitting on top of a 2AA Mini-mag.
To hold the lens to the head, purchase the filter/rubber cap package to get the rubber cap for around $5, or go to another isle in that hardware store and pick up a black rubber 7/8" crutch/chair leg cap for $0.50! Of course the filter cap already has the hole in the top but if your particular lens you find is smaller than the opening, you may want to go with the crutch cap and drill/cut-out your own lens hole. BTW, the crutch cap fits much tighter and deeper onto the head and seems to hold the lens in better. If your lens is a smaller diameter or if even just one of them is, use rubber "o" rings from another isle in that store to space them and/or keep them centered in the cap. Try different spacing of the lens you find. Use "o" rings to space them. Most are air spaced a bit in the camera lens body anyway.
I was fixing to post an image of the beam pattern at 2 foot away, but see that UBB images are not permitted anymore? Sooooo, below is a link to take you to that image. As you can see there is a secondary outside ring of light that helps illuminate the side for that path walking.
4.5 volt w/lens Mini-Mag LED conversion beam pattern
WARNING: After lens conversion, DO NOT LOOK directly into the beam. Serious eye injury will occur if the beam is stared at, at close range.
