Raymond
Made a fixed focus 3D maglite, by \"accident\"
I received my goodies from litho123 this week (see the b/s/t section). I ordered a carley 805, a carley medium orange peel reflector and some WA bulbs.
The carley 805 is a very "long" bulb, with the wire way up in the bulb. Here's a comparison between the standard bulb and the carley:
It means that when you simply replace the standard bulb with the carley, it isn't possible anymore to focus the light into a narrow beam.
I replaced the stock reflector with the carley one, after I made it to fit:
When I assembled the head of the lamp, I placed the carley lamp into the holder, but didn't mount the ring that holds into place:
I remounted the head of the lamp, and because the bottom of the new reflector is still flat:
it pushes the lamp holder all the way down, and lets the head of the lamp just peak over the bottom of the reflector:
which makes for a nice narrow stream of light, which is also noticeably brighter than the stock maglite bulb.
I will order a flashlightlens, and when I mount that, I will find a way to mount the 10W WA bulb.
(which will probably mean I loose this nice way of mounting the carleylamp).
I need some spare parts for that. Anyone who can help me with that? I need a replacment plastic reflector, and also a new battery-spring. (the standard version puts too much pressure on 4 C-cells. I would like to make a shorter spring, but don't want to destroy the one I have now)
