belyo
Step1
- Unscrew the tailcap and remove batteries.
- Dunk the body into water oo:
- When the body is filled with water, close the tailcap.
*note*
You may push a positive battery contact using a stick so that the head
part will quickly be filled with water.
Step2
- Put it into a freezer bag and FREEZE it.
- Wait until the water inside the body turns to ice.
Step3
- When it's freezed, water expands and pushes out the bezel! You can
see a gap between the bezel and body in the picture.
Step4
- To widen the gap, melt the ice and repeat the steps. You may need
to repeat two or three times to remove the bezel easily.
Step5
- The bezel should have no scratch and be flawless with this method.
You can disassemble other parts after you remove the bezel. Now you
can mod it as you like :thumbsup:
Translation support by kj. Thanks!
*note*
Step2
Step3
Step4
Step5
