H & M Flashlight Contest: Class 2 entries
McGizmo
Maui
Those who are entering in Class 2, please place one post here with a brief description and image of your entry. Place a link in your post to the thread that you have started regarding your entry. PLEASE title your discussion thread with "Class 2: { entry name }". This will allow for identification.
This thread is strictly for class 2 entries and links to discussions. Please don't add comment posts here. Entrants are free to edit their posts as needed.
Orion
Missouri
Class 2: AL3AA
Removing mine from the running. It's no longer in existance.
PEU
Buenos Aires / Argentina (I like ribs)
Class 2 Entry by PEU, The TILT-HEAD v2
My entry in the class 2, I posted a similar light as my 1st Mod , then I refined it by adding more leds and a better circuit.
Pablo
Flatscan
Class 2: Horned Toad
Discussion thread
4AA NiMH, BB500, 2 3W TV1J, Fraen LP, stock diffuser
custom heatsink
modifications to stock circuitry (adjusted low-voltage indicator, increased maximum current)
andrewwynn
Racine, WI USA
Class 2: \"Megasonic\"
Talk about timing... just made my first flashlight mod and there is a contest. Hope others enjoy checking it out 1/10th as much as I did making it.
Introducing the "Megasonic"
Summary: took a 100 Lumen, 7W incandescent drill-battery lantern and modded to a 180Lumen, 9W LED megalantern.
Here is the link to the Megasonic Web Site
(note: click on pictures to see full-size on website)
CPF Discussion Thread for the Megasonic
jtice
West Virginia
Re: Class 2: LightPipe
>~>~>~>~>~>~>~>~>~>~ !!!! Entry Withdrawn !!!! ~<~<~<~<~<~<~<~<~<~<~<~<~<
Was completed before the beginning contest date.
---- MagUflex ----
The maguflex is a 2D Maglite, that has been modified with a "Uflex" Circuit and TWAK LuxIII LED.
This project started a LONG time ago, and has been changed, and revamped more times than I can count. Becuase of this, the lights fit and finish is not near what I would like it to be. Half way through this project, I knew this one would end up being a good learning experience. This light turned out really well, and is super useful.
Original Post: HERE. Not sure what happened to the pics. /ubbthreads/images/graemlins/frown.gif
My Webpage for the MagUflex: HERE.
I quick pic.
Icarus
Belgium
Class 2: Mag2D LuxIII nFlex mod (8 brightness levels)
Here is my Mag2D LuxIII nFlex mod with 8 brightness levels. Maximum brightness level reconfigured for 1000mA.
Pewter Mag2D, LuxIII TX1J emitter, blue glow ring, O-Sink, nFlex converter, UCL lens, smooth reflector, using 3xCR123 or 6AA NiMH batteries.
The stock Mag clicky switch was modified to a momentary push button switch.
Pushing the modded switch the user can choose the desired brightness out of 8 predefined levels.
This is the link to the original thread .
Freddy
djpark
SJ, Malaysia
Class 2: Arc-AA 8mm ISP + Micro-P Multi Brightness
Introducing Arc-AA MOD with 8mm Power LED from ISP
and PIC12F675 Micro Processor controlled Multi-Brightness Control
running on 14500 (AA sized) Li-Ion Rechargeable Battery!!
Find out more from this post.
<ul type="square"> [*]5.5 hours almost flat current regulated bright output (130mA) with high brightness mode followed by many hours of moon mode
[*]Over 48 hours useful light (15mA) to half brightness with low brightness mode
[*]Simple high / low alternating brightness control (I did try 3 levels, but found that it is not very practical)
[/list]
-- dj
pbarrette
Huntsville, AL
Class 2: The ArcLuxAAA
Hi all,
Introducing, the ArcLuxAAA:
A 1W Luxeon emitter in the ArcAAA body.
The full page is here
Thanks,
pb
tvodrd
*Flashaholic* ,
Hawthorne, NV
Re: Class 2: The ArcLuxAAA
Hi All, the contest is now closed to further entries. (Unless the Moderator says otherwise. /ubbthreads/images/graemlins/grin.gif )
Larry
