nerdgineer
I found a paper describing the results of 5 mm white LED life (and other) testing done by Lighting Research Center for a conference in 2000. A link is here
What the researchers found is that the 50,000 to 100,000 hour lifetimes most manufacturers claim and most people believe for leds is not true, especially for white leds.
The number of hours for a typical 5 mm white led (circa 2000) runs before degrading to 50% initial efficiency varies with the current level (of course), but even at the recommended drive current of 20 mA, it was less than 6000 hours. When overdriven, the led life (to 50% loss) went down fast: to about 500 (hundred, not thousand) hours at 90 mA and about 200 hours at 110 mA.
Maybe 200 hours is enough (20 AA batteries through an Ultra G), or maybe Leds have gotten better since 2000, but this is something the CPF hotrodders should be aware of.
The article mentions Nichia by name, although it doesn't state what make led they used for the test. They do state that they tried another brand of 5 mm white leds and got pretty much the same result.
The authors note that this may be a unique characteristic of white leds due to deterioriation of the yellow phosphor layer used more than due to breakdown of the led solid state layer itself.
Anyway, my 2 cents.
Anyway, my 2 cents.
