Real men use matches of course. Timing is part of it, not this sissy BS with lighters.....
I too have used the shank rather than tip of the soldering iron with success over the years and can recommend it as a field expedient.
Use of a toaster oven, however, needs to be carefully taken. Temperatures involved might easily kill any number of electronics bits, including the LED. Some die just under the boiling point of water, the rest just over it. You need to be able to selectively heat, the heat gun can kill electronics (experience here....).
Doug Owen
