<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Daniel Ramsey:
Could the LS possibly ever have a tailcap switch? Its often hard to use a twist on type of flashlight when we use gloves and that is why I went to the Brinkmann instead of the Minimag. In looking at the length of the 123 battery case of the LS it could be fairly easy to offer the tailcap switch option <HR></BLOCKQUOTE>
You know... the prototype version Arc-LS has a removeable tailpiece on the 2-AA battery pack. If this hasn't been totally deleted in the production run, it might not be that hard for somebody with a machine shop to cobble up. I'm not sure though if the production Arcs have a one-piece billet for a battery holder, or if the two-piece unit was retained and was simply sealed with Lock-Tite to prevent it from coming off.
An existing switch from some other flashlight could be mounted in a piece that will thread into the LS's barrel. Your "lock off" function could then be accomplished simply by unscrewing the head slightly, the way you turn the light off now.
