<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Ken B:
Hmm...well what I was thinking is...to get 2.5 watts at 3.3 volts they want a temp diff of 365 degrees...now...if we cut the temp diff in half...182...I don`t know...would we get 1.25 watts at 1.65 vlts...I`m sure it`s not that easy of a convertion but would be interesting...BTW...would a Luxeon light with 2.5 watts/3.3 volts...or not even light?<HR></BLOCKQUOTE>
That company recommends that you contact them
for other temperature data, which probably
means it's not a linear function and output
decreases quickly with decreasing temperature, but i wont say too much untill
someone contacts them and possibly tests one
of the devices at a lower temperature diff.
Any idea what the price of the 2.5 watt model is?
Not sure what you mean about the 2.5watt
3.3 volt luxeon, but an LS at 3.3volts and
350ma consumes only about 1.2watts.
Another interesting (?) aspect about using
a peltier to cool an LS is that if the
temperature of the LS is brought down to
very low temperatures, then that means the
heat has to go somewhere else meaning the
other side of the peltier junction is
going to get pretty hot and even a heat sink
might get too hot to hold in the hand
comfortably. If the heat is conducted to
the metal flashlight body, i would bet it
gets pretty hot.
Al
