Erik and all,
Remember I wrote that a buddy will be giving me a spare KL4 bezel? I have it in my possession. I tested both of them, but not in the way I stated in my post. I did not use the L1 in the test. I used the KL4 bezels with the L4 battery tube.
I removed one battery from the L4. While making sure that the remaining battery was making contact with the center post in the bezel, I inserted a steel tweezer into the tailcap end, and wiggled it until it made contact with the battery negative and the tube's body. The light came on. Obviously, the output was not as bright as the light with two batteries, but it was plenty bright anyway. I am impressed by the total light output of each bezel, which is the same wide floodlight pattern emitted by the L4 using two batteries. The tint of each bezel ia exactly the same as when it is running on two batteries. One is white, and the other has a "yellow non-objectionable" tint. I cannot begin to guess what the lumen rating could be, but the overall light output is greater than either my Arc LSH-S, Micra, or L1 with the 3 watt bezel. The hotspot is more prominent than the Arc's, but less so than the other two.
For now, I will give you my current/voltage readings using a "somewhat depleted" battery. For a future test, I will find a dummy spacer so that I can use the light with only one active battery, and do a less tedious visual test due to tweezer manipulation. My haste is due to my desire to share something positive rather than wait, since all of us will eventually have a depleted battery and should know what happens at that point in the battery's life. Both bezels were electrically identical........
Voltage no load = 2.86V
Voltage with light on = 2.70V
Current draw = 140mA
As I look at these numbers and behold the light output, I am amazed at how much light these bezels emit with only one battery, and with so little energy. Unless somebody can prove that I am crazy, my KL4 bezels have a ridiculously low power consumption of .378watt. I think that my fascination in the results is due to the bezels' broad sidespill, even though the hotspot intensity is reduced by the omission of one battery.
I have read so many posts about the KL4/E1e combination, most of them written before I started my LED hobby on 2/17/04. Now I see what the hoopla is all about. Aren't we glad that SureFire has finally released the KL4 bezel as an accessory? Based on my very encouraging findings, I am quite sure that I will be ordering an E1e, very soon. Until that happens, I will continue to be overjoyed with the total performance on my L4 light.
