D
**DONOTDELETE**
Guest
The application is a Petzl Zipka that starts out with 3 White LEDs. I was planning to mount 2 more LEDs in the housing. Ideally I'd like to be able to vary the light output from low to max (30mA) via potentiometer. If this is not easily done, the lamp can be at max all the time.
This lamp is very small, so a couple of small (TO-92) components could fit, but unfortunately not the LM2621 evaluation board.
Which reg should I choose?
LM317L Voltage Reg, Zetex ZXSC300 or LM334Z Current Reg? Others?
What I need help with is component selection and a simple schematic including resistance values. I have a digital camera and will document the conversion for the greater good.
The Zipka is a nice light, really compact and convenient. It's very well engineered from an ergo perspective. I like the high-tech cordreel. If I could just stop it from getting dim 1 hour after I change the batteries!
Thanks, Greg
Thanks, Greg
