It is advisable to avoid exposure, especially visual , to ultraviolet radiation. Accomplish this by steering clear of exposure to UV emitting LEDs, lamps, and excessive amounts of sunlight. While special care is needed when working with lasers, this post does not refer to them. Read the references and take the advice...or leave it! They are, after all, YOUR EYES . In the case of sunlight, protect the skin with high SPF lotion and protect the eyes with properly rated UV blocking sunglasses . UV LED flashlights and all UV energy sources are potentially hazardous. Radiant energy in this band has a well-established causal relationship to cataracts . Observable adverse effects generally result from chronic exposure; however, UV damage to the eyes is cumulative and irreversible . If you must work with UV sources, use approved UV protective eyewear.
http://www.webpost.net/ne/netab/uvleyes.htm
http://www.arn.org/currpage/uvhealth.htm
http://www.aad.org/pamphlets/UVIndex.html
http://www.ncbi.nlm.nih.gov/entrez/query.fcgi?cmd=Retrieve&db=PubMed&list_uids=3185661&dopt=Abstract
http://ohioline.osu.edu/cd-fact/0199.html
http://www.framesdirect.com/lens_options_ultraviolet.asp
http://www.shadeseyewear.com/damage.htm
http://members.misty.com/don/uvbulb.html
Be safe, not sorry!
L3
Be safe, not sorry!
L3
