Tyler,
The PR or the IMS so27xa should drop down into the M2 (SureFire I presume?) from the front end with no problem?!? /ubbthreads/images/graemlins/icon3.gif If you want to feed them in from the rear, a 20 TPI thread can be cut on a PR reflector in a minute and it will screw past the threads and then rattle around if you have removed theshock isolation system.
Sort of related, I am about half way through a modified PR coupled with a McCapsule that will allow for simple drop in of McCapsule/ PR in the classic heads and bodies but not the shock isolated M2. I need to get some parts finished off and off to the anodizers before ican rap this up and I should have anodized McCapsules on friday (fingers crossed) so I *should* be able to post about this over the weekend. I am certainly jumping the gun here but after reading how Chop still "bothers" with the PR's, I wanted to mention this build because it depends on the machinability of the Al reflector coupled with its thermal path. /ubbthreads/images/graemlins/tongue.gif /ubbthreads/images/graemlins/grin.gif In this build, the reflector does have a short length of thread which helps keep it centered as well as keeping it captive in the head if you do a McCapsule change out.The reflector screws past the threads and is then free to float axially a bit. For a 5W build, a .015" thich shim/centering bushing is possible, I think. You have a metal to metal compression and thermal path from the back of the McCapsule to the front edge of the reflector contacting a lip in the head. I think it is the best thermal path I have personally come up with in a classic head and all parts are loose. It looks real promissing so I am sure I have failed to notice a couple major flaws! /ubbthreads/images/graemlins/icon15.gif
