Thanx Don for the info /ubbthreads/images/graemlins/smile.gif
Yeah luxlover, it almost seems that the light is made for 15 lumens long runtime but with a high 65 lumens high output capacity if needed. I think of it like car headlights, normal beam for travelling and a high beam readily available when needed.
In fact I couldn't resist the urge and had gotten it. I see it as a very versatile light that can fit many purposes and usage, being Surefire built and HA3, this thing can last. You can use the low beam for normal walking around and easily switch to high beam when you need to "check things out" if needed.
I thought I was impressed with the Longbow Micra's white beam, but the L4's better. It made my Micra's beam look green on 65 lumens, I previously thought I imagined the green on my Micra's beam, coz its hard to notice. But the L4 affirmed the green on a side by side comparision. On 15 lumens it has a bit of yellowish tint. Its the whitest LED light I have now. Very satisfied with it, more satisified than the time I got the Micra. Throw isn't very good however, but thats because the beam's not made for that purpose I guess. Indoor illumination it is on par with the 6P (65 lumens), if not its better because its white light. Outdoors it lost out in throw and penetration compared to the incandescent 6P.
