I was just fooling around and dropped 3C cels in my 2D MagLite, and noticed if you pull out the spring, you can screw on the end cap. Hmm....
I also then found that 1" 450psi PVC plummng pipe (5" length) fits inside the mag barrel and the C cells fit into the PVC; no rattle.
I then just cut down an old flashlight spring, and after sanding the inside of the cap, inserted it and screwed on the cap.
Click, flash; there goes the bulb...Insert home made PR Base Luxeon bulb...Click...Light
And that's how you can get 4.5V out of a 2D MagLite. Kinda nice, a lot lighter, and power enough for a Luxeon.
Try it, You'll like it......
