<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR> Txwest said
No clue on the Photon 4???, but if you go to order from TTS, ask if he has the ARC LE. If so, get it too / instead of. If not, go for the ARC AAA. If all else fails, get the Photon 3. TX
(not intended to be a put-down for Photon...just a plug for ARC)<HR></BLOCKQUOTE>
The Photon III is due an upgrade "soon". The major part of this upgrade will be the use of the logic in the Photon Fusion headlamp. This reduces the delay between the various modes and also eliminates the ridiculous flashing at the start and end of the auto off mode to something more appropriate.
In the past, I would always have rated the LE above the P3. This was especially true when my P3 was acting up. However, like ARC LRI do offer excellent customer service and unquestionably replaced my faulty P3 with the newer unit - the one with microswitches - when I had problems.
As I see it, the main benefits of the P3 over the LE are as follows:
o It is truly TINY
o Is is a fun light. Lots of modes to play with
o It is very bright. I couldn't believe just how bright until I did a recent side by side comparison with my LE!
o Despite what you may hear elsewhere, batteries are cheap and easily available! I recently purchased 50 Sony-branded batteries (good for 25 changes) on EBAY for 20 US Cents each!
Like the LE, the P3 is fully waterproof. It is now also reliable. Early P3s were bad in this regard, but newer ones are fine. P3s are also always available with the brighter LEDs, whereas the LEs are no longer in production.
Please don't take this to be critisism for ARC, I'm just begining to realise what a wonderful light the P3 is!!!
