New LS spec sheets
D
**DONOTDELETE**
Guest
Luxeon finally released a new Star spec sheet that has some limited info on the new green, cyan, and blue Lambertians.
The Emitter spec sheet was also updated.
One notable change: the efficiency of the acrylic collimator has fallen from 90% to 85%
papasan
Northern Virginia
wonder why there's no change in flux output between the blue chemestry lambertians and batwings...the forward voltage and mA draw are the same as well...
the only difference i see is the viewing angle...
hopefully the whites at least will be an improvement, but i don't see why they would considering the other blue chemestry dies...
carl
los angeles
A quick comparison of the luminous flux numbers seems to show that the low-dome and high-dome bulbs have the same light output with the exception of red ones where the high-dome has substantially greater light output than the red low-dome. I thought all high domes were supposed to have greater light output than the low-domes. Are the high dome bulbs really worth waiting for?
