Now that I've owned both models for a while (several months of owning Arcs, two months of owning Longbows), I'm going to post my opinions regarding preferences. I won't include the Arc-LSH premium models or the Arc-4s since they are in a completely different price range.
Fit/Finish: Advantage: Longbow
Both my 2 Longbows have top notch fit and finish. All parts fit extremely well together, and the 3 HA finish (Olive Drab) is applied evenly and extremely well. I'm talking Surefire quality fit/finish here.
2 of my 3 Arc LSH-Standards have very nice fit and finish. The fit is nearly as good as the Longbow, but the finish is NOT. The Arcs have slight color mismatch on the parts, and the finish is not as evenly applied.
My 3rd Arc LSH-Standard has the infamous "tiger stripes" in the finish, which while it doesn't affect function it sure affects looks and appearance.
Beam quality: even. Both the Micra and Arc-LSH appear to have good beam quality for a flashlight that uses optics. While neither have a "Surefire" quality beam, they both have good beams with only minor flaws.
Beam tint: Significant advantage to Arc.
While every Arc LSH-S I have has some slight tint to it, they are usually so slight that I can't notice it unless I compare it to a very white flashlight side-by-side (Pelican M6 LED). The tints on the Arc LSHs I have range from slightly pink, to slightly purple, to slightly green.
One of my Longbow Micras has a very white tint that is slightly tinted green. The other Micra I have is VERY green--bright cat urine green.
Size:brightness ratio: Its very close. The Micra appears to be slightly brighter, but the Arc is smaller. I'm going to call this one even.
Runtime: advantage Arc. On average, the Arc appears to keep regulation around 30 minutes longer.
Price: Advantage Longbow. On average, a first Arc runs for $99, a Longbow Micra $79-$89 depending on options)
Overall: Advantage Longbow. Better fit/finish (IMO), slightly brigher, yet lower price. In every other area (except tint and runtime), they are pretty much even but I think the Longbow gives better bang for the buck.
I like both models very much, and I will continue to buy both the Micra and the LSH. However, at this point I'm going to be buying the Micras in greater quantity than the LSHs.
This is just my opinion. I'm sure others have much different results. Please post your opinions if you own both models.
