Sub_Umbra
Here's the situation: I have a CMG Infinity in green that has a big hole in the center of the beam. As a test I stuck a piece of Scotch Magic tape over the end to act as a diffuser and I liked the result. Since there is no lens to stick the tape to I need something else.
Has anyone tried something like #0000 steel wool on the offending LED to diffuse it? Did it work? Fine sandpaper?
I know that I will lose some throw with the diffusion, but I could live with the way it looked with tape test.
If you have tried anything directly on an LED to diffuse it please tell me what you did and how it worked out for you. (or didn't)
Thanks
Thanks
