luxlover
Banned
I can't sleep at night! I am plagued by a question that must be addressed by someone. I would like to know how the U2, which will be sporting an output in excess of 100 lumens on high, will be able to dissipate the heat generated by it's 5 watt Luxeon?
My theory...
There are three other lights using 5 watt Luxeons and two 123 batteries, the L4, L2 and L5. We know that the L4 doesn't have enough body mass to dissipate the heat it generates after about 15 minutes, because the bezel gets very hot. Some of us get into the habit of "not" leaving it on too long, even if we want to, because we want our Luxeons to have a long lifespan. I don't think that the L2 has the same overheating problem as the L4, because it is so long that it draws the heat out of the bezel and has more metal further away to keep the bezel cool. The L5 doesn't have an overheating problem. It has more body mass than either light, to absorb heat. It so happens that it is very close in body mass to the U2. The bezels have the same 1.47" diameter, so the heat generated by the U2 at that spot, will have the same means of escape as the L5. The lengths are almost the same.
If the L5 is putting out in excess of 65 lumens, and the U2 is projected to be putting out over 100 lumens, then there must be some mechanism in place allowing the Luxeon to run cooler. Since I am not well informed on Luxeon binning, I am guessing that the Luxeon selected for the U2 must be of such a bin code, that it can put out more light and generate less heat. I think that the word that best describes this general characteristic is efficiency. If my theory is correct, then the Luxeon bin used for the U2 is top notch, and the U2 with it's high output must generate less heat than the L5. Despite this being a logical theory, I may very well be wrong. If I am, I would like to be told so, and at the same time informed of any other possible theories. Most of us are not sure of anything inside of the U2. SF wants it this way, and I accept this.
My theory...
