KevinL
I somehow suspect, not very. It doesn't run for that long on alkaline batteries, and only about 2 hours on NiMH because apparently it is drawing very high current loads. This is consistent with Duracell's graphs for putting an AA cell under a one amp load.
First, a few numbers. Their specsheet mentions a 1 watt Luxeon, and LumiLEDs says drive it at 350mA max. A Vf of around 3.2V (estimate) would give 3.2 x 0.35 = 1.12W. They are using a regulated circuit, which I assume is 70% efficient. In total, the LED, plus circuit should draw 1.6 watts from a 3 volt alkaline source. 1.6W / 3V = 0.533 amps from the AA cells. According to Duracell, the cells should last more than 3, almost close to four hours at 0.5 amps. Using nickel metal hydride and its more constant discharge curve simplifies it even more, assuming you have good 2100mAH cells fully charged, 2100/533 = 3.93 or close to 4 hours as well. 2 hours is more consistent with a 1A drain.
What's up? Is the Luxeon being driven at twice its rated current, which would explain why? That would warrant its battery drain and justify it because you get more light, so it is worthwhile. However, if they are truly driving at 350mA and somehow the battery power is being burned up elsewhere, I think I'll go grab a sandwich instead /ubbthreads/images/graemlins/smile.gif
