andrewwynn
The new face of Megasonic.
before:
after:
I finally got my upgrade and just in time for laborday weekend (camping trip with the family... there is always a face-off of portable lighting).
Anyhow, since the design stage of Megasonic, I had intended the possibility of an upgrade to more emitters.. (4 or 6 being the highest probability)... After some deliberation i decided to go with 4 with an 'ace'...
Went with 4 because the buck puck driver i'm using can just barely handle 4 emitters at nearly max power.. at fully power they are drawing a total of 880mA at 13.3V.. or 11.7W... apparently getting near the limits of the driver, because i can get over 3W/emitter with 3... however saved $25 only using one more emitter 'cause no add'l driver needed.
The ace, you might ask.. picture worth at least a dozen words... rather than using the awesome but small S017XA reflector, i opted for the S027XA... and to quote monty python.. "you chose wisely"... I couldn't be happier.. i wouldn't want to have all 27s but having (3) 17s and (1) 27 works perfectly..
Initially though bright as the sun (pretty much literally)... the center was a pretty bright flood, but some bright incandescents i went up against (namely a 14.4V dewalt light and an 18V crafstaman light) had a brighter hot spot (even though they sucked as a work-light in comparison... spotty, ringy)..
Well I was not going to stand for my brother's 14.4V light bein' brighter... so i ordered up the parts and upgraded my 9W megasonic to 12W... however with the 27 in there... BANG this thing is bright.. can't wait to do a test with a light meter.
After the upgrade... ended up with a problem.. perhaps due to the new power levels.. there was a turn-on voltage spike that would sometimes cause the voltage checker to think the battery was dead and it would blink and shut off :-(... after taking apart the 'sonic and measuring here n there with the precious fluke 87 (can measure a 1ms spike).. it caught the reference voltage from the buck puck spiking to 5.5V, which made my halved reference spike to 2.75 and is supposed to be 2.50. Since i reference that up to 14V to turn off the light, the cut out voltage went from 14.0 to 15.4V, and when the battery is only mostly dead (princess bride fans out there?) it would shut off... but if it turned on, it would stay on 'cause the spike only lasted a few milliseconds.
I only needed to add a capacitor to the leg of the op amp that was tied back to the reference (hysteresis loop) and the ref. voltage now sticks at 2.500, it was amazingly stable.
I had upgraded the switch a few weeks ago so i have a much better control and the dial also includes the switch.
Beamshots ya say?
Well that's one... It's about 15' to the wall.. notice how the entire room is illuminated from the bounce! To see the rest go to the Megasonic Webpage and click on the 12W upgrade
before:
after:
Beamshots ya say?
