Astro_Saber_III
- Joined
- Apr 13, 2004
- Messages
- 19
I hate buying non-rechargable batteries, so I decided to spend $5 on two "2/3AF" rechargable 1.25V batteries and experiment with the E2e. I believe they are 400mAh each. They are the exact diamater as a CR123, but slightly shorter so I had a small brass or copper spacer to make up for the shorter batteries. To my surprise, with the KL1 head, the light was just as bright as having 2 CR123's in the E2e! I used one of them camera light meters to measure the output, which is very unscientific, but gives a general guide to go by. I took two 2/3af's off the overnight charger and put it in the E2e and pointed it at the light meter for 1/2 hour. It only droped 6 numbers on the display (987 to 981) during the first 1/2 hour. I let the E2e cool down for I'm guessing 20 minutes, and it did the same thing for the next 1/2 hour. Then the third 1/2 hour test, the KL1 started dropping output vary rapidly before finally starting to blink on/off every few seconds with low light output.
Needless to say I was very impressed with the performance of the E2e/KL1 combo with the rechargable batteries.
The downside to this is that the original E2e incandecence bulb is dim with only 3V. Also Nickel metal hydride rechargable batteries loose 1-2% of their charge daily with no use. Let the batteries sit for a month, and you'll get almost no runtime because they will be half dead. I just leave one set on a trickle charger, and swap batteries every 4 days or so.
Are there any other alternatives other members have come up with for rechargable mods for the E2e?
