HarryN
Hi - I have been searching for an electrically conductive adhesive / solder replacement.
In order to stay below the temp limit of Luxeons, I have limited the cure temp. to approx 100 C. It appears that in order to obtain cure temps this low, you need to use a 2 part epoxy type, or buy a material that must be stored at (-40 C).
Does anyone know of a material that can be stored at norminal room temp, single part, silver or similar, electrically conductive material that will cure at a temp under the nominal 110 C limit of a Luxeon ? The conductivity does not have to be perfect.
Thanks
Thanks
