Angryfox
Results 1 to 6 of 6
Thread: GLP-III Laser Pictures
    Flashaholic Shiftlock's Avatar
    Aug 2004
    Southwest Florida
    Default GLP-III Laser Pictures
    In case anyone is interested in pictures of the GLP-III 50mW laser, I created a simple webpage with some pictures. This is the laser that takes "C" batteries and has a finned heatsink in the front. The site is at:
    http://laser.shiftlock.com
    Unenlightened
    Sep 2004
    Default Re: GLP-III Laser Pictures
    Looks cool, could you Please post pictures of the beam output. how is the farfield "long dist" beam/spot quality.
    thanks
    Informative photos. Looks like a spanner wrench could unscrew the aluminum part with the two dimples. Can you tell if the heat sink and that aluminum part are separate parts. I ask cause I wonder if the lenses can be swapped out for others to lower the beam divergence. Where did you buy it and what was your cost.
    Thanks
    If you take some photo's in the far field like that person asked,could you do so at a very far field say, >1000'also.
    Thanks
    Flashaholic* lasercrazy's Avatar
    Mar 2004
    NJ, USA
    Just out of curiosity, how long can you run the laser for? I would expect a VERY short duty cycle for a laser like that, like 10 seconds or less.
    Aug 2004
    Southwest Florida
    Lasercrazy, why do you suspect a short duty cycle? It's very beefy aluminum "maglight-feel" case with a large heatsink in front. It has that sturdy "you-could-use-this-as-a-weapon-to-beat-someone-over-the-head"-feel to it. The button is a "click on/off" type so clicking it on and leaving it is very easy and it is made to do that by design. It can be run for a very long time without the heatsink fins even getting warm. Compared to a smaller pointer, I think the duty cycle is much higher, dare I say almost continuous.
