Jack_Crow
Hi guys,
This is a low priority project. Got 93 more days until Im home.
When I get home I will be in the fortunate position to choose between two vehicles. No doubt the vehicle not picked battery will discharge over time.
Depending on my travel schedule they may sit for weeks at a time. Im tired of replacing batteries I let die.
Got this insperation from the Army. One of the cute things the military has on some of it's humvees is a little solar batter charger/keeper. This unit makes enough energy to keep the trucks battery from going flat even if the vehicle is parked for weeks at a time. I can't beg or borrow one form the vehicle repair unit here. Military trucks are 24 volt systems.
The personal car is an I4, and the truck is a large V6. Each vehicle has more than a little aftermarket electronics in it. Figure a car alarm, and some ham radios. My discharge rate will be a little higher than stock. I don't have any numbers at this time. After I get back (in early december) we can get some exact numbers.
Project One.
I want to mount a solar panel on the back deck of the car (L4). Under the rear glass. It should be mountable with screws. Virginia is a bit warm in the summer and adheasives tend to come apart. I want one that can be hard mounted.
Project Two
(V6) It's a full size Chev pick up truck. At this time I don't have a camper back for it. Been thinking about mounting it vertical on the back glass with a bracket holding it in place, or mounting it on the roof. I don't want to mount it military style by shooting it into the hood like the Humvees here.
I know about diode isolation and other related issues.
What I would like is a product recomendation and perhasp links to dealers with stock. These can be ordered and shipped to my home address. I will install the parts when I get home.
The unit for the car will not have to be water resistant. The unit for the truck might have to be.
Im figuring anything between 80 to 150mA in bright sun should be enough.
As a side bar, I was thinking of having a small volt meter mounted in each vehicle.
When you live in an apartment, you don't get much time to look over your vehicles. Mostly check for parking tickets, and see if a tire is flat. I want to get a quick check of the state of the battery on such walk by's.
Something visible from outside the vehicle. A small CB "S" meter with a resistor and a zener diode offset to give a 'segmental' voltage reading. Perhaps an LED to back light the meter.
Ideas welcome, it seems I have the time.
Thanks in advance.
Later people.
Jack Crow in Iraq
Project One.
Project Two
Thanks in advance.
Later people.
Jack Crow in Iraq
