Re: Superluminescent LEDs break 100mW barrier, 155
Pretty "long" for an IR LED, but it is way up top end of the middle IR band, most true IR imagers work around 10,000 nm (10um), though you can find some short IR thermal imagers that work in the 6,000nm to 7,000nm range.
The near IR band 750 to 1300 nm.
Intermediate IR band (also called the middle IR band)
1300 to 3000 nm.
The far IR band extends from 3,000 nm to 14,000nm.
Extreme IR band runs on out to 1,000,000 nm (or 1,000um)
The definition will vary depending on the source, for example:
Near IR: 0.7 - 1.5 mm (700nm-1,500nm)
Intermediate IR: 1.5 - 8 mm (1,500-8,000nm)
Far IR: 8 - 100 mm (8,000nm-100,000nm)
Extreme IR: 100 - 1000 mm (100,000-1,000,000nm)
btw, 1,000,000nm=1,000um=1mm
These above definitions are from Introduction to Naval Weapons Engineering, Introduction to Electro-optical systems.
A great little primer on the EO Spectrum is found here, done by Point Magu:
https://ewhdbks.mugu.navy.mil/eo-ir.pdf
