jayflash
The sudden death of CR123 cells seems to be a fairly common event with high drain, high output, incandescent flashlights. I haven't read about this happening with bright LED lights, yet.
Lights like the L4, PM6 and a few others pull as much current from the cells as their incan counterparts. When used for an extended time, so that the cells heat up, has anyone experienced the "sudden death" syndrome that's common with incans?
The failure mode I'm refering to is when the light seems to be working normally but won't turn on again once it's switched off. This is a different event than normal, rapid, dimming at the, expected, end of the cell's life.
I've only noticed this failure to turn on again, after the cells got quite warm from an extended use. It seems, at this point, to be the cell heating that causes the sudden death.
What has your experience been and do you have a different theory? Thanks for any replies.
