Re: HELP! ! 9 WAVE FORENSIC LIGHTS
I talked in CPF Chat about this subject. I have permission to all in it to post this log. I originally thought of many seperate lights for this but Jarhead had some ideas that might be much better. I will edit this down to relevant parts when my eyes will stay open.
<JonSidneyB> hey guys.....do us a favor...keep this thread alive...we want to see if there ways we can make this happen
<JonSidneyB> bobbie....I am sure that in no time at all....we will get lots of advice
<Luke> I hope so
<JonSidneyB> I bet Jarhead will have some ideas of his own
<Luke> yeah I bet he will
<Okie_Chick> Good because I am lost in the dark on this
<Luke> He'd be the one who would know really, he's very good at this
<Luke> Lots of people on CPF would probably be willing to donate money though
<Luke> and the select few that really know about these topics might be able to donate their expertise
<Jarhead_NewBie> the lowest cost would be a HID with a prism
<JonSidneyB> it would be nice if a way to build a cheaper substitute...then many could benifit
<Jarhead_NewBie> HID puts out IR through visible to UV
<Jarhead_NewBie> a hole would be in the side of the box
<Jarhead_NewBie> the prism is between the HID and the hole
<JonSidneyB> see, I knew Jar would have ideas
<Jarhead_NewBie> you steer the prism to allow the wavelength of light you want out to shoot out
<Jarhead_NewBie> could also be done with LEDs
<Jarhead_NewBie> HID is alot cheaper
<Jarhead_NewBie> fella could prolly get HID setup from auto junkyard, and prism from any one of many scientific surplus joints
<Luke> you can really get HID from auto junkyards?
<Jarhead_NewBie> yeah, usually they want 35 dollars or more
<Luke> wow
<Luke> Honestly, I'm pretty glad you hang around here Jar
<Jarhead_NewBie> you understand how a prism makes a rainbow
<JonSidneyB> Jarhead>any tips on how to get this done would be great
<Jarhead_NewBie> well, it does it from below IR to beyond UV
<Jarhead_NewBie> at one point the glass prism will stop passing the UV
<JonSidneyB> there is a pic of Okie chick here....how can you not help someone with this smile
<JonSidneyB>
http://www.candlepowerforums.com/ubbthreads/showflat.php?Cat=&Number=525342&page=&view=&sb=5&o=&fpart=26&vc=1
<Jarhead_NewBie> if you need UV above that, you'll need a quartz prism
<JonSidneyB> did you see some of the machines currently doing the job
<Jarhead_NewBie> you mount prism on a post that you can rotate
<Luke> would that waste a lot of light Jar?
<Jarhead_NewBie> yes it is Luke, but definitely the cheapest
<Luke> It'd still be plenty of light right?
<Jarhead_NewBie> you mark off the dial for the different wavelengths
<JonSidneyB> Jar>can you make a ball park estimate to what something like this will cost to build
<Okie_Chick> Thanks Jon. . .but what I would like is to have my niece smile.
<Jarhead_NewBie> then you can have an "infinite" amount of wavelengths at your disposal and sent competitors packing
<Jarhead_NewBie> could be free if you had the materials at hand
<JonSidneyB> not looking to sell...just to get made
<Jarhead_NewBie> oh
<JonSidneyB> we would pay you jar
<Jarhead_NewBie> say 200 for HID from Welych
<Jarhead_NewBie> 20 bux for glass prism, dunno quartz prism prices
<Jarhead_NewBie> add a small reflector to focus for the HID, say 20 bux
<Jarhead_NewBie> metal box, not much
<Jarhead_NewBie> SLA battery, say 10 bux
<Jarhead_NewBie> and big dial, say 10 bux
<Jarhead_NewBie> then you just need to mark off and calibrate the dial
<Jarhead_NewBie> unfortunately, think it is 600 bux from welch for a hid kit, they make you buy three
<Luke> they wanted two
<JonSidneyB> a prisim will give a full range of wavelenghts that these devices do
<Luke> perhaps they could sell the third kit
<jtice> jar, its a $100 min order
<Jarhead_NewBie> if you build it JSB, I'll calibrate the dial
<JonSidneyB> hmmm
<JonSidneyB> how much would you charge if you built it
<Jarhead_NewBie> can't promise anything, lots of things going on
<jtice> sounds like a cool project guys, but would the prism really work?
<jtice> wouldnt alot of "white" light excape, washing out the "color"?
<JonSidneyB> Jar>post your ideas
<Jarhead_NewBie> you only have a slit jtice
<JonSidneyB> perhaps we can get someone else to build it
<JonSidneyB> and get you to calibrate
<Jarhead_NewBie> you adjust prism so 635nm is sitting over it, and only 635nm escapes
<JonSidneyB> just think....cpf could be on the cutting edge of forensic lights as well
<Jarhead_NewBie> wider slit, wider wavelength
<Jarhead_NewBie> inside of box is painted flat black to absorb the rest of the colors
<Jarhead_NewBie> gotta go do some work, bbiab
<JonSidneyB> jar...post your ideas sometime
<Jarhead_NewBie> chop up the log and post
<Okie_Chick> Wow. . .Jarhead. . .you know a lot
<JonSidneyB> ok
<Okie_Chick> I appreciate you information
<Luke> Jar's the resident EE expert
<Luke> until of course I get my degree and show 'em up in a few years .
<JonSidneyB> ok....choping and posting
<Okie_Chick> What does that stand for?
<Luke> what does what stand for?
<JonSidneyB> shoot
<JonSidneyB> anyone logging this
<JonSidneyB> it scrolled off
<Luke> I'll save it
<JonSidneyB> thanks
<JonSidneyB> can you mail me the contents
<Jarhead_NewBie> the prism idea is how we used to get various wavelengths we needed for experiments in science
<JonSidneyB> will credit jarhead on his ideas
<JonSidneyB> ummm chromatography?
<Jarhead_NewBie> or to view spectral contents of say an argon light
<Jarhead_NewBie> you use it to produce things like this,
http://members.misty.com/don/spectra.html
<Jarhead_NewBie> in this case we adjust prism to allow whatever wavelength we want to escape
<JonSidneyB> luke, are ya here
<Jarhead_NewBie> you can also use grating to produce spectrum, but you'll need a glass metal version
<JonSidneyB> hmmm
<JonSidneyB> grating
<Jarhead_NewBie> 3200 lumens out of a hid
<jtice> and tilt the angle of the grating to the light huh
<jtice> ?
<jtice> so the holes get wider and narrower
<JonSidneyB> is this like creating a wave length sieve...like poloraiztion but wide ranging
<Jarhead_NewBie> say it emits visible light, due to the lumens rating
<Jarhead_NewBie> Just as for "lumens," candlepower is a measure of brightness that
<Jarhead_NewBie> is adjusted to the selective sensitivity of the human eye
<Jarhead_NewBie> so, say 400nm to 700nm
<Jarhead_NewBie> 300 nm range
<Jarhead_NewBie> divide 3200 lumens by 300
<Jarhead_NewBie> about 100 lumens at each 1nm wide window
<Jarhead_NewBie> most sources actually have a wide emission band
<Jarhead_NewBie> so, say you make the slit so that 30 nm fits through
<Jarhead_NewBie> oops, 10 lumens per 1nm wide window
<Jarhead_NewBie> okay back to subject
<Jarhead_NewBie> so you use 30nm wide window
<Jarhead_NewBie> slit
<Jarhead_NewBie> so you get 300 lumens at that range
<Jarhead_NewBie> you could have a disk with different slits
<shiftd> JAR
<Jarhead_NewBie> so, not only can you dial up the center wavelength you want, but you can also rotate the disk for the bandwidth you want to pass through
<Jarhead_NewBie> which means not only do you have a continously variable wavelength source, which blows out the competition, but you can also adjust the width of the wavelengths you want to pass
<Luke> sounds great
<Jarhead_NewBie> you could use it broad to look for whatever, then once something shows up, you can slip to narrow pass, and dial through until you get to exact wavelength that it peaks at
<Jarhead_NewBie> which helps alot to precisely identify exactly whatever it is
<Jarhead_NewBie> it is nothing more than how they identify what elements are in a star, with some minor mods, working the whole thing in reverse
<Jarhead_NewBie> tq luke
<JonSidneyB> this sounds alot better when how I wanted to approach this....9 seperate single wavelenth lights
<JonSidneyB> and more versatile
<JonSidneyB> Jar, so this is all doable
<JonSidneyB> a couple of grand might be able to cover this?
<JonSidneyB> balamer line coding?
