MacGyverS2000
- Joined
- Feb 24, 2004
- Messages
- 15
Having a difficult time finding what I need. High-brightness red, green, and blue LEDs, elliptical output pattern. Viewing angle should be somewhere along the lines of 30-60 degrees by 60-90 degrees. Brightness levels should definitely be in the high several hundred mcd range, and the brighter the better (2,000+ mcd ideal). Obviously the higher ratings will be with the smaller viewing angles. Expected current requirements are in the 30-70mA range.
Here's the real stumper... it should be SMD (surface mount), not PTH (through-hole). I'll use PTH if I'm forced to, but I would prefer SMD. I've come across a couple of PTH that fit the bill (just in case), but more suggestions are welcomed.
Since I don't check CPF as often as I would like, emailing suggestions is preferred.
