Maxtorch
Results 1 to 2 of 2
Thread: Battery Leak in my Pro-poly 7-LED
    Nov 2003
    Nebraska, United States
    Default Battery Leak in my Pro-poly 7-LED
    Does anyone have recommendations on how to effectively clean up a battery leak? I've never had one before, and it does not appear that the "brown" substance reached the battery spring on the bottom of my flashlight. There is a noticeable amount of brown, toothpaste like substance on one side.....I was using Dorcy AA's and noticed my light wasn't near as bright....hope this doesn't happen too often.
    Flashaholic* nikon's Avatar
    Mar 2004
    Another time, another place.
    Default Re: Battery Leak in my Pro-poly 7-LED
    First wipe up as much as you can with a rag. Then mix up a strong solution of a cleaning solvent such as ammonia and wipe the rest up. Do this outdoors, wear rubber gloves, and don't breathe the fumes.
