ArmyTek
Page 1 of 2 12 LastLast
Results 1 to 30 of 47
Thread: Keychain Light
    Default Keychain Light
    Hi from an obvious newbie to the forum. I think that this is the right place to find the best advice:
    I'm looking for a bright, durable, water resistant or waterproof light for my keychain.
    The new light will replace a little AAA maglight.
    I've gone through two of the maglights.
    I'd like the size to be roughly the same, but want, of course, to find the right balance between size and function. Priorities include: durability, water resistance, light output, battery life, and availability of replacement batteries.
    Price is a consideration, as always. I'd like to be able to order the light, and have it delivered within 2 weeks.
    Please let me know, based upon this information, what is the best light for my needs.
    Thanks for any help you can offer.
    BJ
    Dec 2001
    A very dark world.
    Default Re: Keychain Light
    I would definately suggest an LED of some sort - preferably one which accepts lithium batteries.
    BTW: Welcome to CPF [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
    (Now quicky hide your wallet [img]/ubbthreads/images/graemlins/grin.gif[/img])
    Flashaholic* RonM's Avatar
    Nov 2000
    NJ, USA
    Up until Tuesday, the Arc AAA would have been the light most people would point you to. Unfortunately Arc just went out of business. A real loss.
    IMHO, the best alternative is from Peak LED Solutions . I'd recommend the 1AAA 3LED in the hi power version. It's brighter than the Arc, but has a narrower beam. A very nice light.
    If you act real fast, pocketlights.com might have a few Arc AAA's left. They are the best AAA light ever made of the type you're asking for. The manufacturer has sadly just gone out of business, so the remaining lights are being snapped up. Obviously you won't be able to get warranty service, but the lights have generally reliable, much more reliable than the Mags.
    You will be amazed at what a piece of crap the mag is compared to these amazing little LED lights. Go for the Peak LED Solutions hi power snow white 3 LED version for maximum light and brightest white color. Well worth the money and they ship extremely quickly.
    May 2004
    Fort Worth, Texas
    Let's not forget about the Docry AAA. Or even the Docry AA for that matter (although the AA might be bit much for a keychain).
    These can be found at local stores such as Wal Mart and Target. Both are under 10 bucks each. If you get lucky the Dorcy AAA will even be under 6 bucks.
    These are good choice to try out until you get your hands on a Peak or Arc. Chances are as you get into it, you will want them all!!
    *Retired* The_LED_Museum's Avatar
    Aug 2000
    Federal Way WA. USA
    I was also going to suggest an Arc-AAA, but Arc went out of business a few days ago. [img]/ubbthreads/images/graemlins/frown.gif[/img]
    If you can't find an Arc-AAA on the internet, I too would suggest getting a Peak LED Solutions "Matterhorn" - a flashlight using one AAA cell and having three LEDs.
    I have an evaluation of this flashlight right here if you're interested.
    Arc will always be what I think of first when I hear "keychain light". However since cost is a factor, that gives the nod to the PEAK LED aaa light. I'd go with the Type III HA 3 LED Hi-Power. The brass look good, but add too much weight. You can use NiMH rechargables for EDC (every day carry) or the new litium batteries from energizer if you forsee long storage times or use in extreme conditions. Peak also has VERY GOOD customer service!
    It will be a real step up from the Mag.
    GL
    I appreciate the help.
    I'll clarify: it was a "Solitaire" light that I want to replace. I state that because I've found another AAA maglite that may be what you are basing your suggestions upon. The reason I won't buy a third is because the first two have been lost for the same reason: the body of the light has become unscrewed from the portion that was attached to the keyring, and so it fell off and was lost. Things like this, I see, happen to a flashlight that is on my keychain. Maybe I'll just buy another and secure it somehow if you have a good suggestions. Maybe I'll buy another and just secure it with an o-ring or a rubber band or another loctite way that you experts recommend.
    I need a light that will be a last-ditch source of illumination. The hole on the solitaire is big enough to attach the lash that I need to secure it.
    Should I count out all of the plastic squeeze lights?
    Water resistance is key. Waterproof to 15m is desirable.
    I think that the suggestions so far (PEAK) are too large for comfortable carry in the pocket. I don't need a kuboton accessory.
    Have I really missed the boat on the ARC? Is there nothing else? Streamlight? Countycomm? I have no idea, but this is kind of important.
    I don't have a Solitaire here to measure. Pity, but these others seem bigger, and I don't want a pocketful.
    I envision a 1 LED light powered by a AAA battery that has a button on the back, and will twist on/off, is waterproof to at least 15m, has a hole for attachment, is durable, and has batteries that are found almost universally. Long lasting and bright light.
    What am I looking for?
    I have approximately two weeks.
    I know that it sounds ridiculous to obsess over something so small as a little light, but I really do need something that fits the description. Thanks for your help.
    Sep 2004
    Toronto, Can
    Coastal Cutlery has LED Lensers that are very small. Some run on AAA and others watch-type batteries. Not that bright, but tiny and well-made. Perhaps you should google them and check their site. Good luck.
    You need to move QUICK and find an ARC AAA.
    The ARC AAA led light is nearly a half inch shorter than my Solitaire and is smaller in diameter. The Solitaire is in three parts (head, tail, body) which allows the tailcap to unscrew from the body the ARC is in two parts head and body and cannot unscrew from your keychain.
    Peak does make an "N" cell LED light that is small and only 2.25 inches in length.
    I'll move immediately.
    WHERE???
    I'll buy one on the spot as soon as I can find one.
    It appears that this is what I want.
    WHERE?
    BJ
    paulr suggested pocketlights.com try them first
    Not an option.
    Please suggest an alternative.
    As an aside they haven't been for 4 days, or I would have gone that route.
    Still, thanks man.
    *Flashaholic* KevinL's Avatar
    Jun 2004
    At World's End
    Ebay. One of the CPFers has something here. Be prepared to bid high though...like.. crazy high.
    The CPF buy/sell/trade section is good too, but you have to be fast.
    Thanks.
    Jun 2004
    At World's End
    I was only trying to help by pointing you to a source of lights. I myself have nothing for sale (you can double check the user names).
    Guess next time I'll save the typing.
    *Flashaholic* flashlight's Avatar
    Apr 2004
    Republic of Singapore
    deleted
    Thanks
    Dec 2003
    Fuerstenthum Lippe / Germany
    BENJOHN
    Cool down , angry man !
    Although you are using the F-word too often , you may be kind of right .
    If you are a soldier and really in need of an Arc AAA,
    I´m sure the CPFers will get it for you .
    I´m in with $10 to buy an Arc AAA for BENJOHN .
    Anyone else ?
    Frank
    Oct 2003
    Japan
    Hi BJ.
    Meridian Tactical has some stock of ArcAAA.If you accept their price(almost @$60 [img]/ubbthreads/images/graemlins/faint.gif[/img] ),you move here quickly [img]/ubbthreads/images/graemlins/thumbsup.gif[/img]
    Aug 2004
    central Florida
    [ QUOTE ]
    [/ QUOTE ]
    Whatever the market will bear, eh? Doesn't speak too well for Meridian in my mind...
    JB
    Sep 2004
    Toronto, Can
    "The CPF buy/sell/trade section is good too, but you have to be fast."
    You can say that again!
    Hey...how'd you do that?
    Sep 2004
    Toronto, Can
    "Whatever the market will bear, eh? Doesn't speak too well for Meridian in my mind..."
    Point taken--mental note made...
    wisti, that is a very generous offer, but I really can't accept it. I hope that you are surrounded by people as good natured as you are so that someone is always ready to reciprocate your kindness. Thank you very much sir.
    I'll scour Ebay and the CPF buy/sell section if I have time in the next day or so. I'm sorry that my situation seems so urgent. I am frustrated that what I want is so difficult to find. Maybe many of you share this frustration now that what you all say is the best light is no longer produced or is available. I'll check back sometime in the future to see what's new.
    You all seem to be a great bunch of people who have been quite helpful in showing me that there are alternatives that may fit my needs better than what I've had in the past, but I think that I might have to stay with the maglite just because it's here and one less thing to worry about finding. Thankyou.
    Apr 2001
    Massachusetts
    If I couldn't get an Arc, I'd much prefer a CMG Sonic or a Peak Solutions AAA Led light to the Solitaire. I had a Sonic. I thought it looked butt-ugly and the tailcap turned much too easily but if the thicker o-ring has solved this problem then I would carry it over a Solitaire. Just my personal thoughts.
    I agree with posts about Meridian charging $60 for the Arc. Although it is his right to do so, it puts a sour taste in my mouth. I wonder what kind of impact this will have on the sale of his other lights. Though if you really want one, they're probably going to go for at least that much on ebay. I wish Texas Tactical Supply had some Arcs but I see he does have the Sonic for $9.50.
    Flashaholic* voodoogreg's Avatar
    Apr 2003
    Global
    I wonder if multiple's of less durable, but as bright plastic unit's like princten tec eclipe's, county com's bright cheap light's etc would be a good alternative. not as robust but a half dozen of these with extra batt's would do the job. I mean If life or death is involved it's a little unrealistic to worry about a unobtainable "pinacle" lights like ARC.
    yes a mag is fine, also I think the infinity ultra or CC ultra -G is small enough for this use. In this instance a 1/4 inch here and there is a pretty stupid road block, but a indistructable ultra-G is not. be safe Benjohn. VDG
    Flashaholic doubleganger's Avatar
    Apr 2001
    northwest MS
    If you were willing to go up to a AA size the cmg infinity ultra is a great light. I've carried one every day for over a year and never even notice it's there till I need it. Of course I lighten the weight by using a lithium battery (1.6 oz). About as bright as the arc and MUCH longer run time. I'm still working on the first battery in mine.
