Hi *@*,
I consider myself very lucky that I could get a new ARC 4+ today. Everything is perfect so far, I noticed just one thing I would like an explanation for out of technical curiosity. .)
My ARC is set as follows: primary 3, secondary 7, force primary OFF, RFS ON
When I press and hold the button on lvl 3, the ARC goes to lvl 1. When I let go of the switch, it doesn't always return to lvl 3 at once, but with a slight delay (~200ms). This happens maybe 30% of the time.
This does not happen when I go to full power and back from lvl 7 or lvl 16. Is this normal? I would be very pleased if someone could check this with his ARC.
Any technical reason for this maybe?
Thanks,
Connor
Thanks,
Connor
