Been lurking here forever, and finally registered to ask some questions. I'm doing a project over the next few months that needs a seriously lightweight reflector. I figure if anyone in the world would know how much various reflectors weigh, it'd be a CPFer.
I'm looking for one that will work safely with extremely hot lamps, and focuses to about an 8' (2.4m) diameter beam at 10-20' (3-6m). The kicker is that the lamp + reflector assembly needs to weigh less than 200 grams (0.44 lb) to work in this application. Suggestions for low-power (under 150w), high-output lamps are welcome as well. (edit: cost is not a factor here, so go nuts. /ubbthreads/images/graemlins/smile.gif)
Thanks in advance.
Thanks in advance.
