[ QUOTE ]
flashfan said:
Do I understand it correctly? Performance of the light will not change in any way (output, etc.) from the 1-watt? If so, why change? I would guess this has been discussed before--thanks for a point in the right direction!
[/ QUOTE ]
Yes, you are correct. Swapping the 1 watt Luxeon with a Luxeon III ( Please note the name. There's no such thing as a 3 watt Luxeon) will *not* make a light run at 3 watts unless you also change the drive level.
My own opinion of Surefire's move to the Lux3 part is because the Lux3's seem to be more plentiful and have a more consistant tint.
Also, underdriving a part made to handle between 3 - 4 watts seems in line with Surefire's policy of driving their LED lights below spec, presumably for reliability/longevity reasons.
