chanik,
I agree with you. but if you consider, mAH Capacities of CR2016 & CR2032 Cells, You will know that in Same Space (overall) the CR2032 is able to pack More Punch (mAH).
Also, I Understand your statement about Internal Resistance. In Photon's we are using 2 CR2016 Batteries that means we are having TWICE the Internal Resistance and hence TWICE the Losses. Dont you think so?
According to Datasheets
http://data.energizer.com/datasheets/library/primary/lithium_coin/cr2016.pdf
http://data.energizer.com/datasheets/library/primary/lithium_coin/cr2025.pdf
http://data.energizer.com/datasheets/library/primary/lithium_coin/cr2032.pdf
CR2016 = 80 mAH (Maxwell has about 90 mAH)
CR2032 = 225 mAH (Maxwell has about 250 mAH)
So Thats like 2.8125 TIMES the capacity of CR2016 Cells, Now Considering Capacitor based Charge Pump Drivers, where efficiency is about 99.9% Where are we loosing anything at all ???
Its Definately less than the Internal Resistance Losses of 2 CR2016 Cells Isnt it chanik?
This was all thought & Thats the reason, we felt a need of a Regulated Photon Light.... Further More, Who Doesent like a Regulated Light /ubbthreads/images/graemlins/smile.gif
Also, if you think of runtimes, Assuming LED is driven at 22 mA With 99.9% Efficiency from a CR2032 Battery, What will be the Runtime (atleast Theoritical).... 10 HOURS.... but lets say practically it will be 8 Hours (assuming various losses etc).... Now tell me Wont this be a GOOD thing /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/smile.gif Especially when we are talking about the size of Photon Freedom / Photon Micro III....
If I had enough Facalities at my disposal, I Sure would have developed something of that size with REGULATION /ubbthreads/images/graemlins/smile.gif but.... /ubbthreads/images/graemlins/frown.gif Too bad, I dont have those kind of facalities with me. I wonder if anyone would be interested in making such a light....
Thanks & Regards,
ViReN
